Sorry for late reply I've been working all day.
So after looking again when I wasnt as tired I've realised the fault is with the kitchen ring main. If the kitchen ring main is connected to the fuse board whenever anything on any circuit is turned on (including the other side of the fuse board protected by a different RCD) the RCD protecting the kitchen circuit trips.
The cables go from the fuse board under the stairs up to the bathroom and back down into the kitchen. I've had work done in the bathroom and the kitchen was tiled yesterday so the sockets were disconnected for a few weeks waiting for the tiler (delayed in turning up) before being refit and power turned back on after tiling and that's when I've realised the problem.
Plug in tester shows no problem at any kitchen socket and inspected the back off all sockets and all the wiring is correct with no loose connections.
After disconnecting the cables to make sure it was defiantely what was causing the RCD to trip (it was). I connected just one cable to turn it into a radial to see if there was any sockets that were then dead to maybe narrow down the problem.
When it is connected as a radial all the sockets had power and the rcd is not tripping even when running multiple things on different circuits
