Oh I assumed that is the main switch on the CU. I certainly remember the design.They don’t make them like that any more.
Any replacement would be a different design and, with respect, would need an electrician to supply and fit.
But the RCD, although old, may be working within spec.
So many people who are faced with an RCD tripping think it is the RCD at fault. More often than not it is an external fault.
It lots like the whole installation is protected by that one RCD, and that’s a recipe for trouble.
It’s at this point that you need an electrician to
Test the RCD and replace if necessary
And
Carry out proper tests to see if there is a fault.
Otherwise it’s guess work and random swopping out of different bits. That is time and money consuming.
PS. Looking at the age of the RCD (the phone number is pre-STD so could be 50 years old. This could lead to further updating if your consumer unit/fuse board if it is of a similar age.
