RCD
As you're using sheathed cable (T/E) protected by the MCB in the CU, then you can have the cable btween the CU and your RCD enclosure as long as you need.
I assume that the shower rating/cable rating/MCB rating all tie up?
As for the earth, yes - use a connector block (fixed down) in the mini-enclosure, unless you can get hold of a DIN rail mounted terminal block (like one of these:)
they are available in some of the larger B&Qs...
ban-all-sheds said:
dabaldie said:
(i'm an engineer believe it or not!) :P
So were the guys that built the Mr Magoo Hubble telescope, and crashed a Voyager (IIRC) probe...
Errr - no! Voyager left the Solar System and is heading for Outer Space, as planned.
Perhaps you meant Beagle II ?
Cheers,
Howard
No - not Beagle. Were there earlier Voyagers?
The one I'm thinking of went pear-shaped because of confusion in the s/w between Imperial and SI distance values. It was some time ago.
I think they were applying that theory to beagle Ban
Thanks to everyone who's helped me with this RCD Dilema.I've now installed the rcd unit and had it checked over,everything done ok.
Cheers lads!
