- Joined
- 11 Jan 2004
- Messages
- 44,591
- Reaction score
- 3,061
- Country
If you are getting strange issues with the RCD(s), the solution is easy.
Disconnect a circuit COMPLETELY from the board and retest. If the result is the same, reconnect and move on to the next. Continue until you find a circuit that, when disconnected, sorts out the problem. Then you know that circuit is faulty, causing the strange behaviour. Then when you have ID'd the culprit, you can then investigate to see what the problem is.
But you should test IR @ 500V. Just test LN to E.
And don't just disassociate "the usual culprits": disconnect ALL loads from circuits, just leaving the fixed wiring and accessories in circuit.
