I removed an old electric shower as we're installing a thermostatic shower instead. There's now an unused socket (possibly 45 amp).
Should that be removed or is it safe to leave it in?
Leave the live feed in to the switch in place. Remove the wires on the load side. That prevents any attached wiring becoming live if some paasing person decides to turn the switch on. Or you could remove the live and neutral from inside the consumer unit, if you feel competent to do that sort of thing.
I suspect they are different. I have a shaver socket built into my wall/mirror unit. Never used a mains shaver but I do know the two pin charge lead from an electric toothbrush charger won’t fit in it.
Probably older models.
I use the integrated socket in my mirror to charge oral-b toothbrush and braun shaver.
I mentioned brands in case someone believed I used some special things to fit in the socket.
The plug on a shaver and toothbrush charger are the same, have been for decades. Maybe you bought your toothbrush charger outside the UK?
We have been through this so many times...
Comparison of (top) the BS 4573 shaver plug with its parallel 5.1 mm pins that are 16.66 mm apart with the Europlug with its 4 mm pins converging slightly from a distance of 18.6 mm apart
Oh yes they are.
Assuming you refer to 13A socket outlets. There are rules about where, of course (>3 metres horizontally from Zone 1, bath or shower edges); so most UK bathrooms are simply too small to have such sockets installed.
You have to define sockets. Read post #10. OP confused a socket for a switch. Of course, certain types of socket are allowed in bathrooms, and many types are allowed providing you have a bathroom the size of Hyde Park, but I didn't want to confuse the thread with going into tiny minute detail when it wasn't needed.
I'll let you explain further (it isnt necessary).
