Hi Folks,
The Rear brakes on my daughters peugeot 206 have locked on.Tried using engine power to releaese but NG. Had noticed a few days before that her h.brake movement when putting h/b level up had a lot of travel and you had to pull h/b level to top to get it to hold thought at the time I thought the cable was slack, since the brakes have locked on the h/b cable tension seems to be tight as soon as you pull the h/b lever up.Is the problem likely to be the cable,how do I fix this.Does the rear drum have to come off.Never really worked on rear brakes before.All ideas???
