Just become aware of a problem with my cast footings.
I’ve just cast a 3.5 x 3.5 meter L shape onto the house to take my new extension.. its a cast strip footing 600mm wide and 10 to 15 inch deep depending where in the L you measure it. The trench has been dug out and is on real solid clay / stone bed so very good base.
However, one area where the existing drains ran has been cut deeper initially and was a tad soft. The planning engineer said put a bit of mesh over this area so basically we put rebar spaced off the floor on that leg. Our builder said we could put the left over rebar in below the surface once poured to add additional strength... all was going well and the trench was poured... but then I had to take a call on my daughters car. My ‘Mate’ who was helping for some reason picked a bit of mesh up and placed it into the concrete.. he pushed it down 2-3’’ as we’d done on the other leg....
He told me what he’d done when I came back and I thought nothing more about it until today when I noticed which bit he’d put in... basically I’d been using double squares (16'') by 3.2 meters long (8’’ mesh).. so I’d cut the strips from both sides of a sheet (these went in the base).. this left a strip with 8’’ squares in the middle but with 7.5’’ bits sticking out either side to give a total width of 23” so 584mm... (you see where this is going??....)
So I’ve basically got cast into one of the legs at 2-3’’ deep a piece of rebar where the ends could be close to the side of the concrete... min recommended distance 2’’ !
What to do?.. do I just leave it?...
Or do i dig down the side of the new concrete once fully set (on the outside leg of the L).. and either cast some more in... or put some other protection in there like tar or something to stop any potential of the rebar ends getting wet and rusting into the structure...
If i just left it and it did rust over time.. how long would it take?... 8mm dia bar BTW.. and if it did crack up the footings would it matter as it can’t actually go anywhere and it’s 95% on very solid ground....
Any advice appreciated on this self inflicted issue 
