I see what you mean And.. i guess you'd use the same described method to get the correct height/depth with the bearing cutter? Also.. i have the fine height adjuster with the trend router i picked up. The tumbler has 3 preset depths. Would you normally expect to reach a desired dpeth by combination of one of those settings plus adjuster.. or is it probable you'd need to adjust the tumblers themselves first.. for common cuts?
