Is the Biasi a combi or is there a hot water cylinder and a non combi boiler ?
Did you read the title of this thread or the first line???
Andy
Which I did miss....I did indicate in my third post
It's not so much that the fan is spinning, the boiler needs to know there is enough air flow in the flue IE not restricted.
If you cover the flue or fit one that's too long it should cut out
Not sure whether you are disagreeing? Are you saying if the flue is blocked the boiler should still fire as long as the fan can rotate?
Zero governor gas valve (1:1).
Gas flow being proportional to fan speed.
Sorry, forum rules prohibit any form of gas advice.Not sure whether you are disagreeing? Are you saying if the flue is blocked the boiler should still fire as long as the fan can rotate?
Google is not always your friend, especially when searching for nearly 3.5 hours for not much gain.it's not gas advice to say which are the moving parts, it's in their marketing brochures
anyway, for completeness I realised you meant gas flow is proportional to the air flow through the combustion chamber and venturi hence it provides interlock against a completely blocked flue. The fan still spins with a blocked flue but there won't be air flow. Still doesn't seem safe that it would operate fine with a partially blocked flue though.
