Hi all,
I have just had some electric works done and wanted to check a few things were all above board.
Can you extend a cooker circuit by joining the cable (crimping), old 60's style metal switch backbox left in place new cable joined to existing inside this and filled? Two points here is it OK to leave the backbox in the wall and join the cable in this manner, when carrying high loads?
Is it a requirement to use conduit in a chase, or is it permissible to cable clip to the wall and plaster straight in. (basically means wrecking the wall if ever the cable need to be replaced.
Similar to point 1...but with a standard socket moving it down......joining (crimping) cable then filling in leaving the original back box in place.....plastic one this time.
Having loose cable around the back of kitchen units, should point out when the kitchen is installed you cannot access the cable as it is behind the units, the purpose of this is to allow surface mount socket to be affixed inside cabinet.
Really just wanted some confirmation this is standard practice, as I would have done it differently myself. But not being an electrician this isn't an option these days.
