No - I am asserting that he did not exercise reasonable skill and care, when he said that he did. He did not say "I'm pretty sure I exercised reasonable skill and care". He did not say "To the best of my knowledge and belief I exercised reasonable skill and care".For a start, "...having exercised reasonable skill and care..." actually appears before "...hereby CERTIFY". More to the point, you are effectively trying to use this to negate the "...to the best of my knowledge and belief.." (which comes after "...hereby CERTIFY.."), since you are presumably primarily suggesting that there was a lack of 'reasonable skill and care' consequent upon knowledge and/or belief about the regs being incorrect.
And if it could be shown (as I suspect it could), that he did not have sufficient grounds for believing himself to be competent?As I say, you'd need a lawyer (or a haggle of lawyers) for that one. IMO, in common sense terms, someone who signs that declaration 'in good faith' because their knowledge is inadequate is probably 'incompetent', but probably not fraudulent.
So we can add not knowing what an A3 radial is to the list.I made a mistake. .....I assumed they were spurs of the ring. I'm told they are A3 radials now. There aren't any 20a fuses.....uses the 32 mcb on the cu
OK. I'll leave it for you to discuss this with lawyers if you wish. I've offered my views, but am in no way competent to pronounce on the legal issues.No - I am asserting that ...
What size cable has he used?
Are there really 4 cables leaving the kitchen MCB - 2 for the ring and 2 for the 2 radials?
2) Post a photo of the "kitchen" MCB in the CU.
I find it hard to see the number and size of wires going into a CU with the cover on.Did you mean you wanted me to take the cover off?
But Wylex was the right make...Can do it no problem.....in the electrician's defense he put a wylex type and and I said surely they should all match.....sonhe changed to this tenby brand.
