Think he means me
So the shorter guarantee on the Rapid version should not be a problem then.As a lot of people on here swear by them, myself included, I can't determine who you are referring to as the "Resident Chav", but I can confirm that they are indeed very good
Lucky so and so. How did you wangle that?
Please don't shout at me... I've only scanned the replies. I've had a bad day. Has anyone mentioned the importance filters, make sure the system is as clean as possible, dont forget to reinhibit after draining down to splash some emulsion on the walls behind the rads, or make sure it's serviced annually to comply with extended warrantee? AND MAKE SURE THAT the service interval record is filled in. Ooops... I'm shouting now.
Check this fella's stuff out if you want another recommendation.
It's OK - Glowworm are related to Vaillant in the same way that SEAT are related to Audi...some common parts, but everything is just a bit more plasticky and not quite so well built. Neither are as good as an IntergasHad a quote today for a Glowworm 25 with 5yr guarantee - is this a decent boiler?
