or do you just run it of the back of an existing internal socket ring main and poke through the wall?
If you do that then if ( when ) the external socket is damaged /water logged then the RCD will trip and all the sockets on that ring will not be useable until the damage has been repaired and the RCD can be reset.
Supply the outside socket via a double pole isolator fitted inside the house. This will allow the damage socket to be isolated and the RCD reset.
Or run the outside socket directly from it's own RCD / RCBO in the consumer unit so that nothing in the house is affected if ( when ) the outside socket or something plugged into it goes faulty.
