Recommendations for premium look roofing for shed/workshop build
@moconnell - https://www.sigroofing.co.uk/roofingproducts/
Also wondering if any gone with 'upmarket' corrugated options at all like right middle link on https://themetalroofcompany.co.uk/garden-rooms/ ?
I used similar (the same? cladco are a manufacturer) material from cladco https://www.cladco.co.uk/ on the rear aspects of both my gardenroom and garage because it's an inexpensive option. It's a bit of a pig to cut. I think you'd need a machine of some sort to do more than 1-2 cuts - it's hard work with a hand-held nibbler. You can of course, order sheets pre-cut to the size you need, but you may still end up with a little bit of cutting.
I reckon a DIY metal roof will be about 50% the cost of a DIY slate roof.
Hmm best part was I thought it woukd be easier..
IMO no more or less challenging than slating. Get the sheets cut to exact length, then worst case is two width cuts which you could do with a hand nibbler.
