What distance are these 245mm by 45mm joists spanning and how far apart are they?
450 centres and they span 3.9mWhat distance are these 245mm by 45mm joists spanning and how far apart are they?
Any solid strutting or herringbone strutting needs to be knocked out first, then replaced afterwards. Not difficult with solid strutting - just takes a hammer and a bit o' welly to knock it out, the replacement strutting might be best made new. Frankly, I can't see it being possible to replace herringbone strutting like for like if the ceiling is already installed - you'd probably need to go to solid strutting instead, which can be installed with existing ceilings in place. If there are pipes or wires in the floor, though, it would be a bit more awkward, but it's easier to deal with those if you have the majority of the base plate of the saw to the top - for which a left hand blade saw seems to make more sense. But you may also need a multitool or jigsaw for those casesWhat happens when you get to the noggins?
Just thinking aloud here, in my customary amateur random way - I find myself wondering whether lowering the joists, then re-boarding and skimming the ceiling below might be less work than taking the tops off them...No. It’s my living room. It’s been completed for 3 years
Not just you. In my trade way I was thinking the same, and @robinbanks mentioned notching the undersides of the joists but...Just thinking aloud here, in my customary amateur random way - I find myself wondering whether lowering the joists, then re-boarding and skimming the ceiling below might be less work than taking the tops off them...
Can you move the new joists downwards?No. It’s my living room. It’s been completed for 3 years
The joists can’t be lowered. They sit on block walls and ripping down the ceiling def isn’t worth it.Just thinking aloud here, in my customary amateur random way - I find myself wondering whether lowering the joists, then re-boarding and skimming the ceiling below might be less work than taking the tops off them...
Some of the noggins might have board screwed to them underneath. I’m going to have to assess the worthwhile mess of it all.Any solid strutting or herringbone strutting needs to be knocked out first, then replaced afterwards. Not difficult with solid strutting - just takes a hammer and a bit o' welly to knock it out, the replacement strutting might be best made new. Frankly, I can't see it being possible to replace herringbone strutting like for like if the ceiling is already installed - you'd probably need to go to solid strutting instead, which can be installed with existing ceilings in place. If there are pipes or wires in the floor, though, it would be a bit more awkward, but it's easier to deal with those if you have the majority of the base plate of the saw to the top - for which a left hand blade saw seems to make more sense. But you may also need a multitool or jigsaw for those cases
So my question is, what is the best way to take 20mm of the joists and noggins on the new extension floor?
If I was doing it I would use a biscuit jointer, they go about 25mm deep and the fence can be set almost 30mm
they are designed for plunge cutting not ripping, but I’ve done a few times myself but I can’t recommend on a public forum for somebody to use a tool not for its intended purpose.
Alternatively you could use a groover for a router - they can cut 22mm deep, so running both sides would do it
Groover 60
www.wealdentool.com
either option would get you close to the wa
Normally when boarding ceilings you screw to the joist lines, not the solid strutting. When you have a board balanced on your head with maybe the other end supported on a tee it's kind of difficult (often impossible) to hit a piece of solid strutting which runs at right angles to the joists - it's far, far easier to aim for the joists, because you can see where they are located down one edge of the board, and on the other edge you'll either have pencil marks on the wall (first row) or a nice row of visible screw heads and you can assess where the joist line us quite easily. It would waste a lot of time messing about measuring where strutting was so you could screw into it.Some of the noggins might have board screwed to them underneath. I’m going to have to assess the worthwhile mess of it all.
A biscuit jointer has a fence that swivels from vertical down to 90 degrees and it winds up and down.I’ve never seen a biscuit jointer used. Am I right in thinking the fence would sit on top and that adjusts down to 25mm and then it plunges in the side ?
