Hi all,
First post on this great forum. Am just embarking on installing a ring circuit in my painfully slow and shoestring house renovation. Building control are notified etc and an inspection/testing scheme is in place so that side of things is sorted.
What's puzzling me is how to satisfy 102 in practice where I have to run through stud walls. 3x2 studs, with either 25 or 50mm acoustic insulation as required/deemed wise. So there's an air gap but I assume 102 still applies? Due to practicalities I've already installed boards on one side of a wall, sockets to be added opposite (currently open) side. I could notch noggins but how do I ensure cable is actually touching subsequently installed plasterboard without having enough insulation to force cable up against it? Do I need to run in conduit (2 cables at 2.5mm still ok as per 4d1a? Do I loop through the return cable)? I really don't want to have to use 4mm cable especially as due to the partial insulation depth there will be no genuine problems with heat dissipation
A related query is what method if any one needs to use to support the cable on vertical drops in a stud wall?
Many thanks for any constructive insights!
