Refilling the air gap on a megaflo.. please help!
12 Nov 2024
So I’m trying to refill the air gap as per the inscructions on the tank but I’m struggling to locate the mains cold water supply valve/knob. Can someone please explain this to me like I’m a complete idiot lol. Our megaflo is on the first floor of the house.
Which of these in the picture do I turn to shut off the cold water supply?
1. It the valve with the black handle highlighted with a red arrow in cdbe's response.
2. They are often very stiff to turn. If this is the case you can always turn the water off at the main stop-cock. If doing so, switch the boiler off as well.
Thanks for the replies guys. So I figured it was that valve on the left but I just wanted to make sure
So with that valve shut off, is there supposed to be cold water coming out of the taps still? Because there is
Your cold isn't balanced with the hot, ie: both hot and cold after the prv.
So your cold is teed off before the shut off valve and won't stop when closing it.
You only need to isolate and draw off the hot to regenerate the air gap/bubble.
That discharge pipework isn't right either.
Can you elaborate further on the pipe work please? What’s wrong with it?
I always just turn off the main incoming stop tap - good idea to keep turning it every now and then as well. Then open a couple of hot taps a small amount of water come out the tap then stops. I monitor the tundish and if I see drips then its time to recharge the air gap. It seems to be once every 6 months that it needs ding - could be longer. I then go around running the taps to get the air bubbles out as it spits and splodges until the air is out the pipes and can otherwise catch you out soaking you.
