Regenerating Air Gap on a MegaFlow
4 Mar 2006
Cheshire
Hi
This maybe a stupid question, but I'd like to try regenerating the air-gap on the Megaflow hot water tank. Do I do this with the system on (i.e. water being heated) or turn it off. Or does it even matter?
Better off but it does not matter!
Follow the instructions on the side of the cylinder.
Unventeds should be serviced annually!
Tony
Thanks, I'll leave it off I think, after we've used the hot water up Saturday morning.
It is a year old this month, and thought I'd get it serviced.
I phoned the company this morning who installed it and they say they don't service them! They'd only service the boiler, because the MegaFlow is just a tank!
That response was very frustrating, don't they want my business!
They went onto say they'd still honour the 2 year warranty on the boiler even if you don't get that serviced.
They really mustn't want any business at all, odd.
"Servicing" one of these doesn't amount to much, just some basic checks really. If they came witha pressure guage you could check most things yourself.
Reestablishing the air gap is simple:
  • Turn off inlet at the cylinder
    Open a hot tap - lowest one in the house
    Open the valve on the side by turning it against its spring, until it stops gurgling. You might have to hold it open
    Turn water back on and hot tap off. Done.
Hi
"Turn water back on and hot tap off" Is that sequence important?
I would have turned the hot tap off first, then turn the cold feed back on.
