So this is basically the same sort of inputs I've done in my noddy spreadsheet - but then the actual calculations are much more involved, presumably using actual modelling of some sort (air flow, etc?) rather than just averaging the U values from each element? Is that form ALL someone would need to do the SAP test or just the starting point? I was surprised it doesn't ask how many windows and what size, for instance.
And, is the test entirely analytical and deterministic i.e. if I gave the exact same information to two people would I get the same answer, or is there some human subjectivity? Put another way when you pay someone £300 - which is not a lot of an architect's time, and I can see people charging MUCH less - are they poring over calculations or do they stick it in a computer and press a button, or is knowing how to get the information into the software correctly the skilled part in the same way that using CAD or Photoshop is? Looking at some of the prices I can see advertised, those guys cannot be doing much work at all - but maybe one SAP is NOT the same as another?
If you already have a SAP calculation/certificate, does that mean the building regs inspector will accept it for part L or does it only inform their decision?
Oh and - is the overall output of all this to determine your actual energy use, or your emissions, or your energy cost (like EPC)?
