I am just about to relocate a plug socket to a higher position to make it tidyer for a tv bracketted to a wall in a bedroom, My original socket is directly below where I want to put the new one, Also it is being used to spur off to another point.
The socket I want to move is on the ring main
Could I switch off CU , take out old socket, connect 2 chock blocks to the existing cables to feed the new point above?, Or do I have to take out the old socket cut the cables back to below floorboards connect a JB and feed the new socket from that?
Thank you
Thank you
