Relocating sockets.
Which category as listed below do these junction boxes fall into?
Regulation 523.6
Every connection shall be accessible for inspection, testing and maintanence, except for the following:
(i) A joint designed to be buried in the ground
(ii) A compound-filled or encapsulated joint
(iii) A connection between a cold tail and the heating element as in ceiling heating, floor heating or a trace heating system
(iv) A joint made by welding, soldering, brazing or appropriate compression tool
(v) A joint forming part of the equipment complying with the appropriate product standard.
Regulation 523.6
(iv)...or appropriate compression tool
A slightly educated guess on my behalf would put them in that category, only because the manufactures must be claiming their form of compression joint (tool?) is as conforming as crimping :)
Regulation 523.6
There are several regulations relating to electrical connections. This is mentioned within chapter 13 in regulation 134.1.4 'Every electrical joint and connection shall be of proper construction as regards conductance, insulation, mechanical strength and protection'.
All met, stop there.
That is for all joints.
A joint which does not remain accessible for inspection, testing and maintanence must also comply with regulation 523.6.
As a Handyman, my knowledge of lectrical regulations has now been exhausted. :LOL:
I suggest you (DIYers) listen to the experts and not me. I joined in this post to wind up a few electricians (for whom I have nothing but respect) for a bit of fun.
Sorry lads. :LOL:
To the OP:
You could move the socket positions up the walls a bit, re-using the existing cable. As it is, if they're old they're probably lower than they would be if installed now in a new building (45cm up from floor)
Steve - invest in a pair of crimpers, like these:
not one of these:
Red & Blue crimps for the earth and L/N:
and some heat-shrink sleeving.
Practice a few times on some scrap bits of cable until you are sure that you can make sound joints.
Problem solved - pulled the downstairs wiring free from the stone wall plaster this morning. There is now plenty of slack to reach the new plasterboard wall. Thanks for everyone's help.
