Sorry to add to the list but I can't help but notice the cut outs for the sink and hob are truly awful.
RF Lighting - can you be more specific?
could do with some kinder feedback perhaps guys?
OscarFoxtrot
1. What is the cause of the damp problem? It must be established.
2. what is the relationship between the outside ground level & the interior floor level? External pics showing ground level DPC & air bricks will help.
3. Did you replace the rotten joists? How?
Note: all the joist tails are seated in the external wall.
Is it a cavity wall? Is it rendered?
4. There is low level damp and condensation across the wall plaster. It needs hacking off and rendering. Left on the wall it will smell of damp.
5. Why a street shut-off? Where is your external stop-cock? It must be located and tested.
6. The electrics should be part of a kitchen ring with home runs for any app that needs one. Recessed cable should be capped with metal channel.
7. The plumbing: pipes disappearing into plaster on an external wall are trouble waiting to happen. The rest of the unclipped pipework should be pulled, and redone in one material ( best is copper). Insulated pipes could have been run below the floor. Apparently, the kit fitter cannot solder, hence the plastic fittings.
8. Have finished floor levels been taken into account with the w/t height?
9. The ceiling & the walls need painting (or re-painting) they should have been done before cabinet work. (FWIW: what is the app on the wall above the hob?)
As above, you need to sit down and re-think, & do a properly measured and annotated design plan - dont muddle along or you will only end up with a muddle.
Not sure where in the uk you are but £300 for two 8 hour days labour oop north would be more than fair.
The plumbing now looks good. This is the advantage of employing a proper tradesman. Unfortunately the electrics still look a mess.
If I had the time I'd come and sort this out for you at cost I feel so sorry for you being left with this mess after employing someone in good faith who claimed he could do the job
