Order online at Screwfix.com. For use in above ground drainage systems. Provides ventilation under conditions of reduced pressure when ventilating pipes are terminated inside buildings. FREE next day delivery available, free collection in 5 minutes.
www.screwfix.com
I have cut the stack and fitted this on top, hopefully it sorts me out for a while.
The bit that is left in the ceiling should I cap it off on the roof? at the moment its one of those vent caps or will that be enough to stop water coming in?
If its temporary, pending later removal of the soil pipe and making good the hole in the roof, and it's one of the 'Mushroom' style caps, then I'd chance your arm. If you are leaving the pipe in situ long term then I'd put a sealed cap on it.
