So you are suggesting that the OP should apply the acid & chemical potions you mentioned above to that c/breast in that room?
How would you propose to clean them off?
If you were only proposing chemical cleaning then why mention jet washing?
The building photos in your references are best seen 12 months, or 2 to 3 years after such treatment. They prove nothing in terms of this thread.
Of course, anything can be power cleaned - water lances are used to cut re-barred concrete, & remove all patina from any brick or masonry.
I'll note a single example that was power cleaned 44 yrs ago and has had issues ever since. The Royal Albert Hall in London. Massive damage was caused with long term effects - much of the fabric, terra cotta and brick, has since disintegrated.
