Removing a 1950s fireplace & clay fireback.
28 Apr 2018
Hi I have a 1950s fireplace in my mum's maisonette & need to remove the
surround. I found a thread on here & removed the hearth without any
issue, it also told me how to locate the lugs holding the fire surround to
the wall.
However, before I remove the fire surround I have an issue with the ABM
Milner clay fireback as it seems to protrude out of the wall meaning it
will not be flush with the wall when I remove the fire surround so can I take
that out as well & does it support anything & no at the moment I cannot
see a lintel when looking up the chimney.
Thank you for taking the time to read this.
OP,
Typically, fire backs dont support anything - your fireback was installed in a fireplace opening.
Your fireback was installed in two pieces but once the tiles, & disintegrating back hearth are removed it should be easy enough to remove the fireback.
Just curious - Maybe what your pics show is a later chimney breast pulled out from an original chimney breast.
Is the c/breast above the tiles framed or blockwork?
None of this will affect your removing the fireback.
OP,
Hi sorry real novice what do you mean by framed or blockwork. When you say
in two parts where would the other par of the fireback be. And thank you for
the advice so far.
OP,
The fireback comes as two pieces - look closely & you will see the join. You should have no problem removing the fireback.
Forget about the "Just curious" questions.
OP,
Well Your advice is spot on so far. The fireback came out in one piece & boy did they pack a load of
brick off cuts etc behind it. The fireplace was a surprise. I never thought it would be so heavy, I had to
cut it into six pieces. Rebars running through it & metal offcuts. Anyway, I'm slowly getting there. Thanks
for the advice so far.
OP,
The remaining brickwork inside the fireplace opening is in-fill and can also be removed.
What is your final purpose?
