I'm currently house-hunting and have seen many many properties that are structurally almost identical. They are 1930s built 3 bed semis which have a solid wall running the full depth of the house, front to back, dividing the hall & kitchen from the 2 receptions.
I am yet to see a single one which has knocked through this wall from the kitchen to the dining room so am wondering if it is even possible. The dividing wall is supporting the wall above, which I expect in turn will have roof beams across it. I can see how you would replace a wall that supports ceiling rafters, since you can support the overhang on the beams while you slide the lintel in place, but how on earth would a builder support the wall above while putting the lintel in place??
Based on this information does this change sound possible?
James
James
