Removing a stripped(ish) hex c'sunk bolt
Try pouring some boiling water on it first before next attempt at removal, this may assist you.
If you had access to a welder I would do that before drilling it out
That has never failed for me - the welding heats the bolt up, swells it, and clears the rust. The only thing then, is how to grip it, to undo it, when it's countersunk. I would try to weld a nut onto it, through the hole in the nut.
The plate that is held by the bolts, assuming it is not "keyed" by anything else, get a helper to rotate the entire plate as you try to loosen the screw. Hopefully rotating the plate and screw together will free it.....
Because everyone has access to a welder and knows how to use it.
I take your point but, if I didn’t have access to a welder and only had a few tools, I would go with what Mottie suggested in post #5, the tried and tested centre punch and hammer method.
I would also hammer in a torx key/bit and try that. If you hammer in a torx bit then you can turn it with a 7mm spanner for extra leverage.
Option b is to drill out with a left handed drill as above.
But that isnt the stuck screw, agree its unlikely but worth checking before heating or welding imho.
I know it’s not the stuck screw, otherwise there wouldn’t be a picture of it. But there’s no reason to believe that it wouldn’t be the same.
All I said was that it might be worth checking before the other suggestions as it only takes a few seconds.
I seem to remember a Flymo with the centre screw being left handed.
