Hi Guys
We are refitting our bathroom and I wanted to take up the floorboards to replace the entire floor with 25mm ply in order to attempt a solid finish for tiling.
The wall between the landing and the bathroom is brick and is about 2.4 meters long. When removing a floor board to inspect underneath I noticed that the wall is sitting on the boards almost central between 2 joists. (take a look at the pics, not sure if they really show what I mean)
Clearly removing the boards up to the wall will cause a support issue. So im not entirely sure what to do, I thought about maybe running a 2x4 and fixing under the boards, directly below the wall and then bracing with noggins, would that work? Any other ideas?
Many thanks
Jay
Many thanks
Jay
