Removing cement/mortar around soil pipe joint
2 Nov 2011
London
Hi All
I am fitting a new bathroom, part of which means I'm moving the toilet, to do so I need to spin a 'T' piece in my soil pipe about 100*
However, at present it is sealed with mortar around the joint where the two pipes meet (see pics below) the pipe is cast iron.
So, how do I remove the mortar (if thats what it is?) ?
I'm concerned that if I start chisseling/drilling it out I might crack the pipe :confused:
Thanks!
Rich
looks like old putty. you can try chiselling it out , or applying heat around it to loosen it up. if in doubt just cut it out and use pipe sleeve joiners available from most plumbers merchants :)
