Removing ceramic tap heads
Fairly easy for a plumber to take the handle off.
The OP isn't a plumber. :rolleyes:
You either take it off easily and reuse it or you take it off with brute force and replace it but either way it has to come to effect a repair.Correct?
You seem merely to have rephrased what I'd already written.
Thought that would have been obvious so someone with even a modicum of technical ability far less someone like you with your superior skills that you like to tell everyone about.
Please show me where I've mentioned any skills, let alone superior ones.
AS compatible, as in cheapos?
No.
Not actually an Armitage Shanks manufactured part then which are about £35 plus vat the pair for quarter turn tap internals.
No they aren't. Someone must have seen you coming.
Cheaper to replace the entire taps with new given that you can buy a pair of basin taps for about a £7?
Not actually Armitage Shanks manufactured replacement taps then?
A simple yes or no will suffice.
Yes or no.
