Pump is a brand new Grundfos a rated 15-60.
I had a lot of vibration, changed pump, solved.
I did have a noisy boiler (kettling), cleaned with Fernox DS-40, noise stopped.
Had a new 2 panel rad fitted in lounge, in place of 1 panel.
Leaky pipe to rad so I drained cleaner out and refilled with water for a week.
4 x drain and flushes last Friday, fixed pipe and filled up with MB-1, Leak Sealer and noise silencer, all Fernox.
(I used LS and BNS as just in case measures, didn't think it would hurt!!)
Since 4am Sat morning, chuffing from boiler then banging which comes and goes. Takes ten mins from cold for noise to start.
It's doing my head in
Regards,
Bigsul.
Not an awful lot of muck came out, mainly black dirty water after the original Chem clean.
All the rads get hot, and relatively quickly.
If I powerflush the HE its all 22mm pipe, so that should work shouldn't it?
Or would you advocate another DS-40 clean?
Regards,
Bigsul.
