This may not be of much help to you, but...... I had some old and rusty screws that I needed to be removed from a wooden gate. I heated the screws with a soldering iron (admittedly only 6 gauge) and found that they removed very easily. My first attempts to shift them failed because they just sheared.
Thought I'd mention it because if you could heat the screws a bit it would take a lot less torque/grip to undo them. Might be a problem if they are contacting cast iron though, as that would make a very good heat sink.
Good luck.
Flashbang.
Good luck.
Flashbang.
