There is an annoying fault which affects most of these cars after about 50k miles. Thats about the mileage on most of the cars that I buy!
First I will say that I never used to like auto boxes but this one changes exactly when I would have changed and has a simple manual change feature.
This fault often occurs during the first mile when it goes into "limp home mode" where it sits in a lower gear and does not change at all. It is a bit frightening when you are going at 75-85 on a motorway! Usually all you need to do is to stop, put it into park and restart the engine. It may then complete the journey or return to the fault within a mile or two. Sometimes once a month and other times/cars five times on a 3 mile journey.
My latest a 2005 Scenic II has only recently started this fault and it is ALWAYS accompanied by the "check gearbox" AND always "check handbrake" AS WELL.
No one seems to know exactly what the fault is and dealers mutter about ""a solenoid in the gearbox which will be expensive" and then they walk away!
Now as an electronics engineer, I like to know exactly what any fault is caused by. And what is the "connection" between the gearbox and the handbrake?
My previous Renault only showed the "check gearbox" warning?
Anyone have any ideas?
Usually if John does not know then nobody does!
Tony
Tony
