I have been looking into this a lot and i feel as though it does require planning permisison - even if you are not in a conservation area or listed building. I would like some views or comments regarding this.
It cannot be a similar appearance if you apply a smooth render of any colour over brickwork (unless you rebate the outlines of bricks!).
Even though it expressly says you cannot apply render if you are in a conservation area - but it does not expressly say you cannot if you are outside a conservation area!
Does anyone have experience of actually rendering without consent and getting contacted by an enforcement/planning officer about it?
Does anyone have any experience of being told they do need a planning application to render a brick property?
It is doing my head in with the number of 'official' (planninportal, council webistes) that just quotes the...
"the materials used in any exterior work (other than materials used in the construction of a conservatory) must be of a similar appearance to those used in the construction of the exterior of the existing dwellinghouse"
but then this clearly ,to me anyhow, clearly means that rendering a brick property definitely DOES require planning permission....
thanks for entertaining this discussion....again!
