I was clearing a neglected part of my driveway, in which is situated a manhole cover.
Unfortunately the driveway surrounding it has eroded away leaving a hole around one side.
I removed all the earth and plant-growth, made a suitable base with sand and fine aggregate. I then had some left over high strength concrete and filled it as much as possible.
There was not enough to fully fill the hole however. There is still a void from the top of the drive to the drain surround. So I need to get some more....
However, from what I understand, concrete likes to self level and prefers to be poured into a mould. The concrete I used certainly did not like to be shaped. At the moment it has formed a solid base.
In this case, the drive is higher than the manhole cover. So I wanted to slope the repair to meet the edge of the drain surround.
Is there a type of ready-mix concrete that will hold it's shape a bit like mortar, but with more strength? Or will a mortar mix be OK?
My alternative is to make a mould, but have a sharp drop to the drain surround rather than a slope.
Many Thanks!
Many Thanks!
