Hi, I have inherited a Modern 3200 alarm in my house purchase. I understand this is actually a Scantronic 9800 rebranded. It works well.
Anyway, I simply want to replace the yellow discoloured, plaster covered PIRs with new clean white ones.
Now I only have the user code. The previous homeowners had a contract with ADT so presumably they have the engineer code. We only want the bells.
So can I do it? I’ve read that you need to disconnect the mains, then the power supply auxiliary fuse (don’t know what that is or where it would be in the control panel or as some suggest I might not have one). Switch the wires, keeping things insulated and then replace fuse, reconnect mains, re enter user code x2 and you’re done?
Has anyone any advice on this. I want to do it 4 times over an extended period as each room is decorated.
Many thanks.
Many thanks.
