Yes, but that's not what you said.Yes, I know that, but it's still wireless communication,
Yup.subject to the possible problems mentioned.
As has been said and implied, I think there is a terminological issue here. I imagine that "it's own method" is to use its own wireless capability - which, as you say, will involve a wireless channel which might possibly be 'blocked' at any point in time - such is the nature of the technology. I similarly image that the "WiFi" which "is not required" refers to the standard (usually internet-connected or, at least, network-connected) 'WiFi' system, which is not required for operation of the detectors, but can (if present and working) be used to interact with it.And it's own method is ? What does it do if it's wireless channel is blocked ?
It obviously depends upon the size and layout of the house, but I' sure that one quite often would hear a distant alarm. However, 'quite often' is by no means 'always'- and that, indeed, is presumably the reason for the requirement that alarms be interconnected.They will still work independently though, I can imagine the alarms are quite loud also so would hear.
If it's a reputable make, then one assumes that, as you say, they would be quite 'robust' - but, as bernard has pointed out, there is no way of ensuring that any such wireless connection is guaranteed to work at the moment it is needed. However, although I'm not particularly familiar with this area, I believe that wireless interconnection of alarms is permitted to 'the powers that be' are presumably less concerned than bernard that their communication channel may get 'blocked'.Don't know specifics, but I can imagine due to laws that if the WiFi doesn't work and the use their "own" WiFi system it is quite robust, for safety laws? ... If using their own wireless, it only has that to worry about, no other devices, of course it could get blocked our crash, but again imagine it's been tested so surely it works restart the link somehow?
Indeed and indeed. As I wrote:The usual reason to use wireless linked alarms is when it is impractical to fit the interconnect wiring. It seems retrograde to fit wireless linked alarms where the interlink wire already exists!
Kind Regards, John... if a wired connection is in any way possible, it is always to be preferred to any sort of 'wireless' one.
If the channel is blocked by transmissions from some other system the alarm can only "re-start" once the channel is clear.but again imagine it's been tested so surely it works restart the link somehow?
Well which is it? Do they use WiFi to talk to each other or not? It would seem a ridiculous idea to use WiFi instead of something simpler, but then there are far too many people "designing" products these days who don't have the sense to come in out of the rain.I can imagine due to laws that if the WiFi doesn't work and the use their "own" WiFi system it is quite robust, for safety laws?
Do they know? Do they periodically try to send/receive signals to verify that they can communicate? Is there actually a link which needs to be established, or is a protocol of that level of sophistication not used?If using their own wireless, it only has that to worry about, no other devices, of course it could get blocked our crash, but again imagine it's been tested so surely it works restart the link somehow?
Assuming that figure is roughly correct, it might be worth trying to put it into perspective ....Calculating the maximum delay in the interlink between fire / smoke alarms due to blocking from one or more nearby and compliant system does give a result that suggests there would be no significant delay ( from memory ) in 99.95% of incidents. ... For the other 0.05 % the delay would increase the risk to the occupants by delaying but not preventing the interlink.
That is based on the blocking caused by adjacent and compliant systems. The effect of blocking from the non compliant equipment alters that 0.05% significantly. These may transmit for many minutes if the user holds the button pressed as they are intended to block all activity on the channel.the far smaller risk associated with the "0.05%" bernard mentioned above.
One might indeed decide that - but so many RTAs (I gather we now have to call them RTCs!) are due to deliberate human behaviour and/or human error, I'm not sure what 'pretty high cost' methods of 'avoiding RTA risks' you had in mind.Or you might (quite rationally, IMO) decide that the price of avoiding RTA risks is pretty high, whereas the price of avoiding flaky wireless interlinks is not.
