The top push down terminals are used in some fittings, but again they are for 1.0 mm solid cable, NOT stranded.
I would be llooking at replacing that wire with high temp 1.0 mm solid lighting cable, last resort would be crimping a solid cable to the existing, but thats last resort if the wires cant be removed.
Is this light worth all the effort.
