- Joined
- 9 May 2017
- Messages
- 12
- Reaction score
- 0
- Country
Apologies if this question has been posted before, I did try searching...
Need a replacement hot water cylinder. Replacing a 1970s copper one. I believe I need an indirect vented cylinder with no coil inside. Set up is similar to any indirect system but hot is heated from an old AGA, no pumps/CH/electric currently attached. My basic understanding is that I should be wary of (the current) standard cylinders with a coil as they suit pumped systems.
Anyone got some suggestions as to what I should buy or be searching for?
Looking for about 120 L, Water in/out is 18mm and AGA in/out is 28mm.
Looking for the simplest solution. If I haven't explained things well please ask for further info.
Thanks A.
Thanks A.
