There is only one way to solve a problem and thats at the scene.
Tony, your statement this time holds little water, in fact I would say it is invalid as Fluff had posted enough information to choke a horse. If you say you needed to be in front of the boiler in this case, then it can only be construed that you were too preoccupied to put forward your ideas that boiler should be range rated (when it cannot), carry out bucket test (when the bucket test has big holes in it) and calling people that had visited site previously, names or questioning their professionalism.
I come here looking for what other guys have to say, from which I endeavor to hone my skills. It would appear you come here to run others down from an uppity stand thereby shooting yourself in the foot.
""You might wonder why I don't spend more time writing help topics but its exactly because others then mess them around and spoil them.""
Above is regards bucket test, which was carried out to no avail. You and half the country (if attending the call) could have carried out this test till the cows come home, and still the location of blockage would not have been established. If you pride yourself as good engineer look at drawing submitted by Chris and apply your bucket test. I cannot see how you could pinpoint the blockage.
If you want to dissect this post, I am game. It was quite clear where the defect lay long before I was invited to attend site.
You said
It needs balancing! BUT if you have a modern boiler there should be a differential of 15-20° C across flow to return.
14 degree differential was posted on page 1.
If so what balancing has been done?
No balancing was needed except the big radiator that was repiped as suggested by D Hailsham
Danny, if you read the last eight pages you would see that they have already done the bucket test and it indicates good flow to each valve.
You dont seem to recognise the other problem of short cycling because the CH power is set at max.
Whats needed is to set it to minimum to prolong the firing time and to minimise the anti cycle time to reduce the boiler off time.
NONE of above was valid..
Posted: Sun Aug 29, 2010 8:32 pm Post Subject:
Above post by Chris is what switched the lights on for me.
There is no more point in beating about the bush here. Let it be said some fine gents who regularly post here have shown their professionalism by posting valuable information here. To Tony I say, read the 20 pages and you might learn something. It pains me to say this as you are a clever man with large reserves of knowledge which is hidden by your constant belittling of others in the trade
