Hi all,
With my Mira Supreme 9kw shower finally giving up on me I reluctantly forked out for a Mira Advance ATL 9kw shower as it was supposedly the best 'fit' in terms of pipework.
Anyway, I had a plumber visit today and aside from the pipework not being as easy as first thought he also mentioned as an afterthought that the 32A MCB in the fuse box should actually be a 40A. So the shower wasn't fitted and he walked away with a £30 callout
Now, as far as I understand it, if my cabling is 6mm then I'm really stuck but if it's 10mm then I might get away with just replacing the 32A MCB for a 40A MCB?
So, my 2 questions are:
* How can I tell which size of cabling I have?
* Is it really possible just to change the 32A MCB unit for a 40A MCB if my cabling is 10mm?
I should also maybe mention that the consumer unit is fitted with a 30mA RCD.
Hope that makes sense!
Cheers.
Cheers.
