Replacing a 34 year old timer on oil fired burner - advice needed
17 Sep 2020
The title says it all. I've had the same oil burner in the house from when it was built. It's regularly serviced and works brilliantly but it does have an old timer system that I'm desperate to replace.
This is the current setup. A 24 hr dial timer with a separate thermostat switch.
a>
Q9dRmrV
6mj5pdm
5FmxQH3
yQ92h5n
The oil burner heats both the water and the radiators. There is also a separate hot water on/off switch in another room. There is a thermostat on the side of the boiler that is pictured above.
If love to be able to replace the current timer with a a Hive system or something similar. Even a programmable electronic timer would be a massive improvement.
Do you have any recommendations?
Do you have a room thermostat anywhere or is that boiler stat the only temperature control for the house?
Electrically any modern timeswitch with a relay output (which is most designed for heating- stay away from any timeswitch designed for lighting) will do. Have a look at the likes of Toolstation and Screwfix to see what they've got and decide what you want (do you want app control, geofencing and all that or do you just want to have different on-off times for weekdays and weekends)?
I'm not a fan of the proprietary brands (Hive, Nest etc)- the apps are all very lovely and shiny but the hardware is pricey and you're at the mercy of the supplier and the internet for continued functionality (that setup of yours has probably done 34 years and will probably do another 34 years).
Thanks so much for the reply. Yes, that is the only thermostat control for the whole house.
Honestly, just the ability to program for the weekday and weekends would be ideal. At the moment we only have off and on over a 24 hour period. I'll take a look at your recommendations. I just worried about compatibility with such an old system.
When the CH is on the water is always heated. It just heats the water as it heats the radiators. I never even realised you could do it any other way as this is the only central heating system I've used.
There is a separate switch for the HW so it can be turned on independently from the CH.
yes kind of thought that would be you your setup, you wil lneed a programmer that supports gravity Hot water and pumped central heating, unless you want to update some pipework and add zone valves, basically when HW is asked for power is sent to the boiler to tell it to come on , and the water circulates through the HW Cyl via gravity, when you switch the heating on it brings the circulator pump on which pumps the water through the radiators, so you an have hw on its own or HW and CH together but not CH without HW
Same system as mine......Thorn Panda 55 :ROFLMAO:
I don’t want to interfere with it until the inevitable happens so its a Homebase timer for me, and shiver once I get home for a while.
John :)
If you do not want to invest heavily, but increase control, then you could replace the timer with a 2 channel programmer, and incorporate the hot wates/heating switch into the circuitry, complemented with a wireless room stat. It would all fit into the existing location.
