Hi
A couple of questions in one, I want to change the very old centrifugal fan in my bathroom - which I had a look at once and is connected by ducting to a ventilation shaft that runs through my block of flats.
First; just wanted to check - is it ok to replace the fan under part p, it sits above the toilet (and is an old silovent connected with ducting to the toilet!). i know i can change the light it is connected to for a similar model but how do i work out what is similar, and
Second; can i use the existing ducting - or should I replace it if it is really old?
