First post, but I have trawled through previous posts as much as I can.
I currently have a 22 year old system that’s a bit like triggers new broom… last straw was this week when I got an At Risk notice on the Ali flue corroded through, which was replaced quickly under my BG home care package.
The current system is Potterton SS 50L (14.7kw) feeding a Boiler Mate2000 BM210 thermal store. It’s been a good if not troublesome systems over the years, but the recent hikes in gas prices means the 24/7/365 of on time required to keep the store up to temperature for even the HW to work in summer means I want change to a more conventional unvented tank system that I can heat up the HW on a timed basis. Also I think the store itself is a ticking time bomb now for leaks given its age.
The house is 4 bed, 1 bath 2 shower and BG heat loss/required calcs showing that 18kw is sufficient for the house paired to an unvented 210lt indirect tank.
Layout would be similar with the boiler on the ground floor on external wall in the utility room and the tank in an airing cupboard on the first floor. Most of the existing pipe work would be repurposed after power flushing (not able to power flush currently due to thermal store!).
Currently I’ve 2 solutions both with the Gledhills SSL 210ltr unvented tank and a Hive 2 control system. One is heat only boiler Vaillant EcoTec Plus 418 the other is a system boiler EcoTec Plus 620.
It’s obviously not going to be cheap so I want to get it right and am erring to the System boiler solution.
However my biggest bug bear with BG is they don’t do Vaillant controls to fully utilise the modulation capabilities of modern boilers for heating. It’s as if they are stuck in a year 2000 mindset and want to set the boiler at one point and not utilise the modulation intelligence available or even the different temps for HW and CH. It’s very nearly a deal breaker for me.
My queries to the floor are;
1. Is the Vaillant 418 a bit old tech?
2. Is Vaillant 620 a good system boiler?
3. Can the Hive2 really properly control the system with its simple on/off logic?
4. Has anyone got BG to fit Vaillant controls to their Vaillant boiler?
5. Any alternatives?
TIA
TIA
