Could someone advise please?
Our Heating system is open vented with an indirect hot water cylinder. The boiler is a Glow Worm Ultracom 30 HXi and the pump is a Grundfoss UPS 15/50. The radiator pipework is 10mm microbore and there are TRV's all but one radiator.
Currently there is a 15mm gate valve between the flow and return, after the pump and before the 3 way valve. I asked the plumber that installed the boiler whether an auto bypass valve should be fitted instead but he said it was fine as it is. However having since read the boiler manual it states that an auto valve should be fitted. To my mind this would also help the system heat up faster and be more efficient as all the water from the boiler is sent to the rads when they initially warm up before the TRV's close instead of the current valve that is always slightly open - Is this the case?
Can the auto valve just be fitted in place of the current gate valve?
