Replacing Glow Worm Flexicom control box front - DIY job?
9 Aug 2006
Lancashire
Apologies, I posted about this a couple of weeks ago and got one reply suggesting it's not a DIY job because air flow needs to be checked but the thread has dropped back to about page 4.
We had our Flexicom 24HX serviced and the engineer issued an advisory notice because the plastic hinges on the control box front have snapped off, prolonged heat having made the plastic brittle. He said a technician visit would cost £300 but suggested to Mrs RR that if we could source the part we could get a "local handyman" to replace it.
Then somebody on here said it's a technician job because the air flow depends on a seal around the display window, but I can't understand this because the boiler is open at the bottom of the case.
This is the part:https://www.wolseley.co.uk/product/glow-worm-20025182-control-box-front/
Replacement is a simple snap fit of the circuit board then fit the cable grommets into their spaces. I can do this. Any reason why I shouldn't?
job should done by a RGI. I would have thought if you supplied the part a qualified engineer could fit it for less than hours work
