So 2010 is going to be a busy time for further renovation of our Victorian terrace (4 storeys, including the basement kitchen/storage area) and starting to get quotes re replacing the boiler. The current one is only 10 years old but has been leaking seriously on and off for a year or so and is now living on borrowed time (we have a stock of radseal but thats only a short term fix IMHO). The floor beneath it is increasingly rotten due to the leaks - its directly over our outside store/outhouse and you can see the beams when looking up towards the boiler! Boiler is situated on the ground floor.
Anyway, we will be moving the hot/cold water tanks into the attic rooms where the header tank is currently. We are also going to be doing some serious work on the attic rooms - completely replacing the roof, insulating, adding an en-suite, radiator etc which is why I need some idea of what boiler would be ideal.
At the moment we run 8 radiators and 1 bathroom from the boiler, but the new one will need to run 12 radiators, two full bathrooms, and a cloakroom (sink only).
Are there any boilers we should avoid or ones that are recommended? Obviously this is going to be an expensive year
