I made a thread on the difficulties of finding a builder/window company prepared to install external lintels on a 1930s property. The vast majority would only specify "angle irons". It got to the point where I ended up specifying the required lintel to the builders themselves.
Even then, with seemingly so much work available, I found that many quotes came back very high (pricing themselves out), or just did not really get back to me.
The quotes are still very variable. So I thought I would get some further opinion.
In total there are 5 external leaf lintels required. Two are 2.3m, two are approximately 1.5m and one is 1m.
Builder 1: FMB registered - quote via text
Just for the two 2.3m openings with some repair to brickwork above (some brickwork drop is present) £2000+
Builder 2: FMB registered
Scaffold £288
To carefully remove brickwork from window head to four windows at rear and one to side landing window.To supply and fit new angle iron lintols, catnic or equivalent. To make good to brickwork and render as required
Cost £1635.00 + Vat £327.00 = £1962.00
Total:2250
Builder 3: Recommended by a builder who could not do the work.
Take out soldier course of brickwork above each window.
Clean bricks to re use.Fit single skin lintel to opening
Re lay soldier courses. Where rendered, patch as required ( no painng allowed for )
Take down triangle of brickwork to rear window only where
cracking has occurred and re lay.
Total cost including materials and scaffolding £1350.00 (I'm not sure if this includes VAT) but if not then 1620
This builder is not FMB registered (not that I can find). Nor can I find much information about his company other than a facebook page of completed works (which look good). So I am a bit unsure. He did assure me is has indemnity cover.
To clarify, this is for the external leaf lintel only. There is a solid timber lintel on all windows internally.
So in summary, it has been far more difficult a process finding a builder who is prepared to quote for the work. It seems to fall into a gray-area of not being big enough and not small enough to be worthwhile in time/cost.
Thank you in advance for any advice.
Scaffold £288
Total:2250
