Don't forget - drain cock for internal stoptap, no lead allowed on your side before first potable tap, capping off/maintaining neighbours supply if it's a CSP, mechanical stopend at boundary (not the little cap that comes with the pipe). If you are running in 4" soil pipe and you have bends then consider- 2 x 45's instead of 90's - possibly cheaper than rest bend and consider feeding the pipe through the sections before you connect them all together if access is tight.
When I've done them they've inspected- trench (with tape measure) but have accepted that it can be 750mm from the future finished floor level, eg if you're having a driveway on top of what's there, they like the sand in the trench, insulation in ducting - they'll check both ends, caps on ducting - have them in place but not fitted so they can see the insulation. Stop tap, drain cock and pipework to first tap, arrangements for capping any CSP, temporary stopend at boundary. They may ask about backfilling trench (they'll want to hear that you're backfilling with xyz and compacting every 150mm).
The ones I've done they've inspected then raised the connection job (normally done within 6 weeks in my area).
