Please explain why you think that an 8725W shower will draw 41.xxx Amps, without using any "on site variance".Calcs (as you well should know) should be based on 230v, not the on site variance.
Ok- You're smug, sanatmouous attitude is starting to lift hairs on my neck.
Due to this, I'll have a final attempt at explaining something that you don't seem to understand.
The OP mentioned a 9.5kw shower.
For calcs I was trained (maybe wrongly ) to assume 230v as the voltage. It was re-iterated during all training segments that 230v was to be used.
Not (and I'll repeat the word, not) the 'real' site voltage- which I understand could change over the life cycle of a installation (say sub station change, major add on's in local area demand etc).
So why do you think the 41.xxx is so way out ??
Rather than just attempting to make others look stupid (such as your childish black and white interpretation of 'x' being wrongly typed when it was bloody obvious it was a divide that should have been included) give us your methodology regarding your calcs.
Then maybe progressive debate would follow rather than you just coming across as a bit of a pendant / jerk with nothing better to do than split hairs.
I'd rather use time helping people that might be appreciative, than defending myself against your poor humoured, nonconstructive responses.
Trans World Airline Tea comes to mind
